Home Theatre hookup dead
Larzuk
Is it even possible to hook up the S3 to a HT Receiver? I have a 3.5mm jack to L/R Audio cable, However it won't stream the music through the Receiver. I'm just curious if I'm missing something, Or it's just not possible.
Thanks in Advance.
You make sure you selected the right source on the receiver and Plugged it into input and not an output?
Yea it's on an input and on the proper source selection.ie..the port I plugged into..I'm just not sure if something needed to be switched in settings or what. Hmm.
