home wifi
Hello and welcome to Android forums! :)
Try to connect manually. Go to menu>settings> wireless & networks>wifi settings and make sure your network is listed. If it shows the SSID, tap on it and see if you can connect. You may need to enter a passkey if you have your wireless network security enabled.
You should also check in the forum for your specific phone model to see if this it common and what solutions will be out there.
