Help homerun battle 3d app problem
stevenn21
hi guys this is my problem:
i used to have homerun battle 3d version 1.2.3 but decided to upgrade to version 1.5.4 thats when the problems started.
when i uninstalled the older version i installed the new one without any issues but when i tap items it says:
"The device information was sucessfully retrieved. This process will be skipped from now on. Accept"
"restore........ restoring only cash items if you want to restore goldball items play match-up game once."
then it says:
"sorry the application homerun battle 3d (process com.com2us,HB3D) has stopped unexpectedly.Please try again. FORCE CLOSE"
i tried setting up adb to try sort the issue but was unable to.
I tried for hours diffrent methods and drivers but it wasnt haperning for me so adb is not an option.
i have factory reset my phone at least 6 times and even unmounted usb memory and deleated it as it askes you if you want to do this at factory reset.
i deleated everything off my sd card as well
so then i reinstall the homerun battle 3d version 1.5.4
and i get:
then it says:
"sorry the application homerun battle 3d (process com.com2us,HB3D) has stopped unexpectedly.Please try again. FORCE CLOSE":mad:
can anyone help? where the hell is it storing the data? i dont care if i have to start the game from scratch at least i could play it! thanks guys and girls
then it says:
and i get:
then it says:
same problem. please keep me updated
yes it was a bad download
download it from somewhere else
remove the version you have installed first before installing the new one
install the next version up from the
this is how to fix it:
install version 1.2.3
then the next version and so on untill you get to the latest version
remember to uninstall the previous version before installing the next one
Thanks. Wish you'd replied sooner. I wouldn't have reformated my phone and SD card. I downloaded it from somewhere else though
