I have not had much luck googling this info... What I did find is something to the effect of modifying the data cord.
Would this idea work?
I want to get a powered usb hub.
I would get a double male ended usb cord and run that from the pc output to the droid bionic HD dock and plug the Seagate 1tb drive into the usb hub.
Would that work?
I tried plugging the external hard drive into the HD dock directly and the Bionic appears to recognize it! But I can't open it.... From my understanding the HD dock doesn't supply enough power.
So that is the only way I can think of doing it.
Do you think it's worth a shot?
Would that work?
I'm heading up to best buy right now to pick up a powered four port usb hub. Seems like it should work.
