Hi, My rezound is running the Unofficial CM10.1 JB ROM (It came like that when I bought it used a month ago) and I get God awful wifi and bluetooth reception with this thing. To get a full signal it needs to be within 2-3 feet from the router and 10+ feet away from the router.....forget about it. and bluetooth doesn't even reach 3 feet, basically unusable.
I looked up on the ROM support page for this particular rom on xda and no one else seems to be having this issue, I install the updates they release regularly but nothing has helped. If it actually is a rom issue I will gladly go to a stable rom or even the factory one, but wifi and bluetooth are both critical for me.
I get 3G/4G signal like I would any other phone so there is no problem there,
Thanks!
Thanks!
