Help Hotmail in Android 3.1
EEE Pad
I can't get my hotmail.ca account to sync with my email on my eee Pad Transformer.... help!! I've tried everything....POP3, IMAP, EXCHANGE, even changing the incoming and outgoing servers to...EX: pop3.live.ca and smtp.live.ca... I keep getting a message saying it can't connect to the server or its not supported.
Make sure you're connected to internet FIRST.
On the stock email app, select new account, put in your hotmail email address and password, it will do everything for you.
not sure if it will do a hotmail.ca account, so if it doesn't, start with a hotmail.com account, ignore the failed check, then go back in after it's configured and change it to .ca
Try setting up in exchange, leave domain blank and use m.hotmail.com as server. Works a treat on my Hotmail.co.uk account
