Help Hotspot - enable after restarting automatically
koutroul
Hello I have a new m8s+ and I turn on the hotspot and when I restart the device I need to enable the hotspot again. Is there any way, even from command line or by modifing start up scripts to have the hotspot always being started on boot ?
Thanks
You might look at using Tasker or MacroDroid to sense power up, and then have it invoke Hotspot.
I am going to try that now... BRB.
Yes it will!
But you must sense Screen Unlock.
It won't do it direct from a power on as DATA is not up and running yet.
It gave a "hotspot error" message.
Macro Droid did it by triggering on Screen Unlock.
That should take care of you.
