geoclooney
I used SVTP for hotspot on my old ICS phone. To use it, you would open the app and type in the settings for your hotspot, and the notification bar would show an SVTP icon while the hotspot was active.
On my new Note 2 (Verizon), I've tried SVTP, Foxfi, Fattin and one or two others. They all do the same thing--activate the native Android "Mobile Hotspot." To be clear, this process works for me, in that when I set up the "Mobile Hotspot" app, other devices connect and they have internet access. The icon in the notification bar is the native "Mobile Hotspot" icon.
I get no popup about signing up for hotspot services, and I've checked My Verizon and it doesn't show I'm signed up for mobile hotspot. But I'm worried that if it's using the native app that I'm somehow detectable or otherwise subject to Verizon adding the hotspot feature to my plan.
Should I be worrying and/or looking for other options, or should I man up, be happy it works and get on with my life?
