Help How can I create a shortcut to a Settings submenu on the Droid 2 Global?
w53cig
I know you can create shortcuts to the main Settings menus (battery use, bluetooth settings, etc.) by just long-pressing the screen -> Shortcuts, but I need to create a shortcut to a submenu (specifically Settings -> Wireless & Networks -> Mobile Networks -> Network Mode)
This is on a Droid 2 Global. Anyone know how I can do this? I have LauncherPro and I know you can make shortcuts with it but programming those shortcuts seems pretty complicated. Also I know you can make additional shortcuts using the LauncherPro "Activities" menu but I can't find the "Network Mode" settings in that list either.
Any ideas?
Idk any other way. Settings is a pretty long list in activities. Are you sure you didn't miss it? It should have definitely been in there. Every activity is, and I've never not been able to find what I need in there to make a shortcut on my home screen. That's weird.
Here's a screenshot of every activity under "Settings"...I tried the ones that sounded most likely (band mode, manage networks, SIM network lock settings) to no avail.
Do you see any that might be right?
