I've searched and searched and haven't found an answer
How do I reset my X10 Mini pro????
One answer I found:
"You can always do a full reset of your phone by going to - settings >SD card & USB mass storage...>Factory Data Reset!!"
When I go to "SD card..." there are no options to reset??
Where am I going wrong?
OK... so I know you reset by doing a software reinstall... I don't really want to install onto my PC - unless I absolutely HAVE to!
Is there no way of just reseting on the phone itself??
Somewhere else I read: you press bottom right and left keys and then press the power - erm... not working for me
Thanks
OM
One answer I found:
Thanks
OM
