Juan Carlos Rodriguez
Hello everybody and this time I want some help about the Android 4.3 I have installed on my smartphone. Recently I got a Samsung Galaxy ACE 4 with Android 4.3 version installed, and it works fine, but the last week I installed an app from Uptodown.com in order to record all the phones (Call Record I think was the app) and I tried to run it but without any result... so I decided to desinstall... everything Ok, until some time ago when I received a call from my wife WITH ANOTHER RINGTONE!!! (I was assigned to her a particular ringtone..) and when I check the phone ringtones... ALL the news installed were gone... so I tried to re asign the ringtones to my contacts but I couldn't do it because the original audio app didn't recognize the music on the SDCard although it was there when I searched with the files explorer... the same with the Galery app, it doesn't recognize the photos on the SDCard... this was amusing for me. The rest of the applications work fine on the phone ...
I check viruses, malware and similar and found nothing... So I think the application broke some internal settings on the phone.
The help I need is the following:
1.- Can I fix the configuration in order the factory music player, galery and similar recognize all the files associated on the SDCard?
2.- In case it can be fixed. Can I reinstall the Andriod 4.3 OS version? or I have to get the original factory version?
3.- In case I can reinstall the Android OS, where I can obtain a good and trusted copy???
4.- Can I install ANOTHER Android OS version? Like 4.4 or similar? It has to be the Samsung oriented ?
Thanks for reading this post and I really need your help, oh, excuse my english
Sincerely
Juan Carlos
CUBA
Sincerely
Juan Carlos
CUBA
