How can I get Adobe Flash?
markw10
I have a Motorola Xoom and installed Adobe Flash for it. My fiancee recently ordered a Google Nexus 7 but I read the article about how Adobe Flash was going to be removed from the Google Play store but unfortunately the day it was removed was just one day before her tablet was going to arrive.
My question is one of her favorite websites is heavily flash based. One thing that made her get Android is the fact that the iPad didn't have flash. Since it's her own tablet she is using her own Google Play account so I assume that she is not able to get items that I have in my own Google Play account.
Is there any way for her to get flash?
Are there 3rd party apps available other than Adobe Flash for her to play flash?
Is there a way for her to get the actual Adobe Flash? Since I have the Adobe Flash app app on my Xoom is there a way I can copy it to her Nexus 7? If so, how would I do that?
Are there any other app stores or websites other than Google Play that would allow this app to be downloaded?
Thank you for your help.
You might be able to copy the Adobe Flash apk from your Xoom to a SD card and then transfer that copy to her tablet. I use "AppSaver" which allows me to copy apk files of apps to my SD card. This is a must have, so you can back up your apps and restore them when they are moved from the market.
Thanks for the above suggestions. I may Google adobe flash apk. I have seen files such as FLV on the Amazon App Store that seem to do flash but I'm not sure if this is as good as having Adobe Flash. Does anyone know if this is a good option?
I can say I'll be getting Appsaver for my Xoom. Sounds like a great app to have and I'll see if I can do that to get the Adobe Flash apk onto her Nexus 7.
