Root How can i get the battery to display 1% charge/drain from the stock 10% increment/decrement ??
ravinOrion
The battery shows up 10% increments while charging and the same decrements while discharging. I love it to see by 1% as it gives me exact idea as what used the battery while i was doing what. Soooo... by any chance/mod can i get it to 1% display order ... !!!
Rooted moto here ... :)
Okay... So finally I found This App which displays in status bar ... 1% increment while charging and 1% decrement while discharging.
Its Called ... MotoCharge
https://play.google.com/store/search?q=motocharge&c=apps
... Guess will use this till the ICS update ... :)
