Help how can I move entire home screen
I don't think you can; I believe you have to move each item at a time.
I'm subscribing though in case someone else has a solution.
When you press the home button and get the wide/zoomed out view of all your screens, you can hold down any one of them and move them.
It took me a while to find this solution to this.
Let me know if it works.
Doesn't work on my phone. Running Virtuous 3.2, which is based off the Sense used in the August OTA (not the NOV OTA), but the Kernel used in the NOV OTA.
On my Samsung with Android 4.0, you can select Menu from any home screen, then Edit, which than allows you to drag and drop entire pages wherever you want them.
