bhtfjthfyhr
Environment
Host OS: Windows 7 (32 bit)
Android SDK Tools: 24.4.1
Android SDK Platform tools: 23.0.1
Android SDK Build-Tools: 23.0.1
Package: Android 6.0 (API 23)
Eclipse Java EE IDE for Web Developers : Mars.1 Release (4.5.1); Build id: 20150924-1200
Platform targeted by my project: Android 6.0 (API Level 23)
Version of the platform running in the emulator: Android 6.0 (API Level 23)
Emulator device : Nexus 7
CPU device : ARM
RAM emulator : 768
Steps reproduced
1. Open Eclipse
2. Eclipse > Run project
Expected results
Connection to MySQL DB
Results
Myapp is running. At finish receive message on emulator : Unfortunaly, myapp stopped
Logcat
Main.java
CPU device : ARM
RAM emulator : 768
Steps reproduced
1. Open Eclipse
Expected results
Results
Logcat
> 12-10 20:07:01.247: E/AndroidRuntime(1211): FATAL EXCEPTION: AsyncTask #1
12-10 20:07:01.247: E/AndroidRuntime(1211): Process: com.myapp, PID: 1211
12-10 20:07:01.247: E/AndroidRuntime(1211): java.lang.RuntimeException: An error occurred while executing doInBackground()
12-10 20:07:01.247: E/AndroidRuntime(1211): at android.os.AsyncTask$3.done(AsyncTask.java:309)
12-10 20:07:01.247: E/AndroidRuntime(1211): at java.util.concurrent.FutureTask.finishCompletion(FutureTask.java:354)
12-10 20:07:01.247: E/AndroidRuntime(1211): at java.util.concurrent.FutureTask.setException(FutureTask.java:223)
12-10 20:07:01.247: E/AndroidRuntime(1211): at java.util.concurrent.FutureTask.run(FutureTask.java:242)
12-10 20:07:01.247: E/AndroidRuntime(1211): at android.os.AsyncTask$SerialExecutor$1.run(AsyncTask.java:234)
12-10 20:07:01.247: E/AndroidRuntime(1211): at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1113)
12-10 20:07:01.247: E/AndroidRuntime(1211): at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:588)
12-10 20:07:01.247: E/AndroidRuntime(1211): at java.lang.Thread.run(Thread.java:818)
12-10 20:07:01.247: E/AndroidRuntime(1211): Caused by: java.lang.NoSuchMethodError: No virtual method execute(Lorg/apache/http/client/methods/HttpUriRequestLorg/apache/http/client/methods/CloseableHttpResponse; in class Lorg/apache/http/impl/client/DefaultHttpClient; or its super classes (declaration of 'org.apache.http.impl.client.DefaultHttpClient' appears in /system/framework/org.apache.http.legacy.boot.jar)
12-10 20:07:01.247: E/AndroidRuntime(1211): at library.JSONParser.getJSONFromUrl(JSONParser.java:109)
12-10 20:07:01.247: E/AndroidRuntime(1211): at library.UserFunctions.loginUser(UserFunctions.java:29)
12-10 20:07:01.247: E/AndroidRuntime(1211): at com.myapp.Main$Login.doInBackground(Main.java:168)
12-10 20:07:01.247: E/AndroidRuntime(1211): at com.myapp.Main$Login.doInBackground(Main.java:1)
12-10 20:07:01.247: E/AndroidRuntime(1211): at android.os.AsyncTask$2.call(AsyncTask.java:295)
12-10 20:07:01.247: E/AndroidRuntime(1211): at java.util.concurrent.FutureTask.run(FutureTask.java:237)
12-10 20:07:01.247: E/AndroidRuntime(1211): ... 4 more
12-10 20:07:07.789: E/WindowManager(1211): android.view.WindowLeaked: Activity com.myapp.Main has leaked window com.android.internal.policy.PhoneWindow$DecorView{4c8d81a V.E...... R.....I. 0,0-374,326} that was originally added here
12-10 20:07:07.789: E/WindowManager(1211): at android.view.ViewRootImpl.<init>(ViewRootImpl.java:368)
12-10 20:07:07.789: E/WindowManager(1211): at android.view.WindowManagerGlobal.addView(WindowManagerGlobal.java:299)
12-10 20:07:07.789: E/WindowManager(1211): at android.view.WindowManagerImpl.addView(WindowManagerImpl.java:85)
12-10 20:07:07.789: E/WindowManager(1211): at android.app.Dialog.show(Dialog.java:319)
12-10 20:07:07.789: E/WindowManager(1211): at com.myapp.Main.login(Main.java:147)
12-10 20:07:07.789: E/WindowManager(1211): at com.myapp.Main$1.onClick(Main.java:63)
12-10 20:07:07.789: E/WindowManager(1211): at android.view.View.performClick(View.java:5198)
12-10 20:07:07.789: E/WindowManager(1211): at android.view.View$PerformClick.run(View.java:21147)
12-10 20:07:07.789: E/WindowManager(1211): at android.os.Handler.handleCallback(Handler.java:739)
12-10 20:07:07.789: E/WindowManager(1211): at android.os.Handler.dispatchMessage(Handler.java:95)
12-10 20:07:07.789: E/WindowManager(1211): at android.os.Looper.loop(Looper.java:148)
12-10 20:07:07.789: E/WindowManager(1211): at android.app.ActivityThread.main(ActivityThread.java:5417)
12-10 20:07:07.789: E/WindowManager(1211): at java.lang.reflect.Method.invoke(Native Method)
12-10 20:07:07.789: E/WindowManager(1211): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:726)
12-10 20:07:07.789: E/WindowManager(1211): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:616)
12-10 20:07:10.040: E/WindowManager(1211): android.view.WindowLeaked: Activity com.myapp.Main has leaked window com.android.internal.policy.PhoneWindow$DecorView{9781f4b V.E...... R.....I. 0,0-180,114} that was originally added here
12-10 20:07:10.040: E/WindowManager(1211): at android.view.ViewRootImpl.<init>(ViewRootImpl.java:368)
12-10 20:07:10.040: E/WindowManager(1211): at android.view.WindowManagerGlobal.addView(WindowManagerGlobal.java:299)
12-10 20:07:10.040: E/WindowManager(1211): at android.view.WindowManagerImpl.addView(WindowManagerImpl.java:85)
12-10 20:07:10.040: E/WindowManager(1211): at android.app.Dialog.show(Dialog.java:319)
12-10 20:07:10.040: E/WindowManager(1211): at com.myapp.Main$Login.onPreExecute(Main.java:163)
12-10 20:07:10.040: E/WindowManager(1211): at android.os.AsyncTask.executeOnExecutor(AsyncTask.java:604)
12-10 20:07:10.040: E/WindowManager(1211): at android.os.AsyncTask.execute(AsyncTask.java:551)
12-10 20:07:10.040: E/WindowManager(1211): at com.myapp.Main$6.onClick(Main.java:144)
12-10 20:07:10.040: E/WindowManager(1211): at android.view.View.performClick(View.java:5198)
12-10 20:07:10.040: E/WindowManager(1211): at android.view.View$PerformClick.run(View.java:21147)
12-10 20:07:10.040: E/WindowManager(1211): at android.os.Handler.handleCallback(Handler.java:739)
12-10 20:07:10.040: E/WindowManager(1211): at android.os.Handler.dispatchMessage(Handler.java:95)
12-10 20:07:10.040: E/WindowManager(1211): at android.os.Looper.loop(Looper.java:148)
12-10 20:07:10.040: E/WindowManager(1211): at android.app.ActivityThread.main(ActivityThread.java:5417)
12-10 20:07:10.040: E/WindowManager(1211): at java.lang.reflect.Method.invoke(Native Method)
12-10 20:07:10.040: E/WindowManager(1211): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:726)
12-10 20:07:10.040: E/WindowManager(1211): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:616)
Main.java
Java:
package com.myapp;
import library.DatabaseHandler;
import library.UserFunctions;
import org.json.JSONException;
import org.json.JSONObject;
import android.app.Activity;
import android.app.Dialog;
import android.app.ProgressDialog;
import android.content.Context;
import android.content.Intent;
import android.content.pm.ActivityInfo;
import android.database.sqlite.SQLiteDatabase;
import android.net.ConnectivityManager;
import android.net.NetworkInfo;
import android.os.AsyncTask;
import android.os.Bundle;
import android.text.method.LinkMovementMethod;
import android.view.View;
import android.view.Window;
import android.view.inputmethod.InputMethodManager;
import android.widget.Button;
import android.widget.EditText;
import android.widget.TextView;
import android.widget.Toast;
public class Main extends Activity {
private Dialog d = null;
Button login, demo, about, bRegister;
TextView loginErrorMsg;
EditText etName, etPassword;
private static final String TAG_SUCCESS = "success";
private static final String TAG_NAME = "name";
private static final String TAG_FULLNAME = "fullname";
private static final String TAG_EMAIL = "email";
private static final String TAG_PHONE = "phone";
private static final String TAG_DATE = "date";
private static final String TAG_SSID_CONNECT = "ssid_connect";
private static final String TAG_SSID = "ssid";
private static final String TAG_USER_UID = "uid";
SQLiteDatabase sampleDB = null;
String username = "", password = "";
[USER=1021285]@override[/USER]
UserFunctions userFunction = new UserFunctions();
boolean yes = userFunction.isUserLoggedIn(getApplicationContext());
if (!yes) {
if (!isNetworkAvailable()) {
network_error(getResources().getString(R.string.network_error));
setRequestedOrientation(ActivityInfo.SCREEN_ORIENTATION_LANDSCAPE);
setContentView(R.layout.main);
login = (Button) findViewById(R.id.bLogin);
login.setOnClickListener(new View.OnClickListener() {
public void onClick(View v) {
// TODO Auto-generated method stub
login();
bRegister = (Button) findViewById(R.id.bRegister);
bRegister.setOnClickListener(new View.OnClickListener() {
public void onClick(View view) {
Intent i = new Intent(getApplicationContext(),
Register.class);
startActivity(i);
demo = (Button) findViewById(R.id.bDemo);
demo.setOnClickListener(new View.OnClickListener() {
DatabaseHandler db = new DatabaseHandler(
userFunction.logoutUser(getApplicationContext());
db.addUser("restaurant-myapp", "Restaurant Myapp",
"office@myapp.ro", "0720191423",
"15-30 31-12-2013", "Dezactivata", "MYAPP",
"x1x2x3x44");
Toast.makeText(getApplicationContext(),
"Conectat cu succes la Restaurant Myapp !",
Toast.LENGTH_LONG).show();
start_menu();
about = (Button) findViewById(R.id.bAbout);
about.setOnClickListener(new View.OnClickListener() {
about_dialog();
} else {
start_menu();
void about_dialog() {
d = new Dialog(this);
d.requestWindowFeature(Window.FEATURE_NO_TITLE);
d.setContentView(R.layout.dialog_about);
d.setCancelable(true);
d.setCanceledOnTouchOutside(true);
TextView link = (TextView) d.findViewById(R.id.tvLink);
link.setMovementMethod(LinkMovementMethod.getInstance());
Button bOK = (Button) d.findViewById(R.id.bOK);
bOK.setOnClickListener(new View.OnClickListener() {
d.dismiss();
d.show();
void login() {
d.setContentView(R.layout.form_login);
etName = (EditText) d.findViewById(R.id.etUsername);
etPassword = (EditText) d.findViewById(R.id.etPassword);
loginErrorMsg = (TextView) d.findViewById(R.id.tvErrorLoginMsg);
Button bLogin = (Button) d.findViewById(R.id.bLogin);
bLogin.setOnClickListener(new View.OnClickListener() {
username = etName.getText().toString();
password = etPassword.getText().toString();
InputMethodManager imm = (InputMethodManager) getSystemService(Activity.INPUT_METHOD_SERVICE);
imm.toggleSoftInput(InputMethodManager.HIDE_IMPLICIT_ONLY, 0);
new Login().execute();
d.show();
class Login extends AsyncTask<String, String, String> {
private ProgressDialog pDialog = null;
DatabaseHandler db;
JSONObject json_user;
int success = 0;
protected void onPreExecute() {
super.onPreExecute();
pDialog = new ProgressDialog(Main.this);
pDialog.setMessage("Conectare...");
pDialog.setIndeterminate(false);
pDialog.setCancelable(false);
pDialog.show();
protected String doInBackground(String... args) {
JSONObject json = userFunction.loginUser(username, password);
try {
if (json.getString(TAG_SUCCESS) != null) {
String res = json.getString(TAG_SUCCESS);
if (Integer.parseInt(res) == 1) {
success = 1;
db = new DatabaseHandler(getApplicationContext());
json_user = json.getJSONObject("user");
password = username = null;
db.addUser(json_user.getString(TAG_NAME),
json_user.getString(TAG_FULLNAME),
json_user.getString(TAG_EMAIL),
json_user.getString(TAG_PHONE),
json_user.getString(TAG_DATE),
json_user.getString(TAG_SSID_CONNECT),
json_user.getString(TAG_SSID),
json_user.getString(TAG_USER_UID));
} else {
success = 0;
} catch (JSONException e) {
e.printStackTrace();
return null;
protected void onPostExecute(String file_url) {
try {
pDialog.dismiss();
pDialog = null;
} catch (Exception e) {
pDialog = null;
runOnUiThread(new Runnable() {
public void run() {
if (success == 0) {
loginErrorMsg.setVisibility(View.VISIBLE);
} else {
Toast.makeText(
"Conectat cu succes la " + db.getUserDetails(2)
+ " !", Toast.LENGTH_LONG).show();
d.dismiss();
start_menu();
protected void onResume() {
super.onResume();
void start_menu() {
Intent menu = new Intent(getApplicationContext(), ChooseMenu.class);
menu.putExtra("order", "no");
startActivity(menu);
finish();
private boolean isNetworkAvailable() {
ConnectivityManager connectivityManager = (ConnectivityManager) getSystemService(Context.CONNECTIVITY_SERVICE);
NetworkInfo activeNetworkInfo = connectivityManager
.getActiveNetworkInfo();
return activeNetworkInfo != null && activeNetworkInfo.isConnected();
void network_error(String error_type) {
final Dialog d = new Dialog(this);
d.setContentView(R.layout.dialog_network_error);
TextView error = (TextView) d.findViewById(R.id.tvNetError);
error.setText(error_type);
Button settings = (Button) d.findViewById(R.id.bSettingsError);
settings.setOnClickListener(new View.OnClickListener() {
startActivityForResult(new Intent(
android.provider.Settings.ACTION_WIRELESS_SETTINGS), 0);
d.dismiss();
Button refresh = (Button) d.findViewById(R.id.bRefresh);
refresh.setOnClickListener(new View.OnClickListener() {
Intent intent = getIntent();
finish();
startActivity(intent);
d.show();}}
