Root how change theme not Rom
G-Ann
using Liquid thundersense 1.4 ..just want to try different themes..or is it possible to get certain ones instead of changing everythin..like color of progress bar,etc
It is definitely possible to update the theme without changing the ROM. Depending on what type of file you download, installation will vary. If you download an .apk, Just install it like an app. There are plenty of great themes out there that have apk's, just take a little time to search around here and xda. If you download a .zip file either "install zip from sd card" inside Rom Manager or install zip from sd card through recovery (Recomended). Theme's should not delete any of your user data and wont wipe anything. They just flash or install directly on top.
