I created a simple app a year ago and that was a nightmare as so complex a thing to create and was glad when it finished.
anyway, have been trying to update things like text and images which has been easy as used winrar and just transfered files in, however I have had to change one of the xml files and thats where my problems start.
I was able to unencode the xml file from binary to a readable/editable file which I have done however I cannot figure out how to recode it back to a binary xml.
It seems there is plenty of applications that convert it to a readable form but nothing to convert it back.
All I wanted was to change font color and size but that simple task has turned into a challenge.
Can anyone tell me how to convert it back to binary or can anyone do it for me if I send them the file?
