How do I delete Play Next on smart tv- permanently ?
its a Blaupunkt - but Most android Tv's have this - I can not find the app for it - if it is a system app -then even harder to find and remove - https://www.androidpolice.com/2020/...tent-from-your-play-next-queue-on-android-tv/ - I think system apps are hard coded into TV ?
System apps are usually hard coded. It could be something Blaupunkt, i.e. the manufacturer has done?
I've never seen this "Android TV" myself, and the only Blaupunkt I ever had was the radio in a car I had back in the 80s.
I have Android TV Boxes and the latest Google Chromecast with Google TV and the closest thing I saw to 'play next' was a feature in the YouTube app that auto-plays the next video it recommends and it's the first thing I disable (after the Play Store)
So is it an app at all? If you mean "how do I stop it playing the next programme after the one I'm watching finishes?" that's likely to be a feature of the particular streaming service - quite a few of them do that no matter what platform you are viewing on. So if that is what you are asking about you'd have to check the settings of each service's app for an option, and if there isn't an option you are stuck.
