Help how do i disable the lock pattern
miltk
lg vista vs880
android 5.1.1
ever since the sys update, i no longer see the notification when the screen is locked. i have to unlock the screen in order to see if i have any notifications, and that is becoming very annoying. on the lg vista there's no disable function for the lock pattern i set.
anyone familiar with the vista or 5.1.1? or help?
BTW,,,clearing credentials, as mentioned in another thread, doesn't disable the pattern screen. also btw,,what does clearing credentials do otherwise?
thx
