psyxologos
Hallo everyone. Just a quick question. When I go to my contacts and see 'e' on the top, I press to edit but nothing happens. Any idea why this is happening and how I can add my information? Many thanks!
Might help if there was a screenshot so people could see exactly what you're pressing, but if you are pressing the edit button and nothing is happening then your phone could be bad. Try doing a reset of the phone but know that everything installed will get deleted, so do a backup first. You could also try taking it back to the store and let them look at it for you![]()
I have done all that they declared to me that they were perplexed at the problem and did not know what was going on...
They have to call themselves guru because nobody else will
What model of phone do you have exactly?
I managed to get it sorted myself now, after spending a couple of hours.
Have you checked contacts>menu>my profile>menu>edit? May be obvious, but lets get those obvious ones out first.
See.... now you know more than those 'guru's do![]()
