A
Android Question
Guest
Right, So I've got an HTC Incredible and I'm fairly sure I need a new charging port but I figured I'd ask around before fiddling with it and replacing it.
The charging on this phone is entirely wacked. I've tried countless cables and countless port options, so I've definitely isolated the issue to the phone itself. I'm currently with a wall charger and I've got it battery optimized. ATM its actually charging, but I can unplug it and plug it in again and like 99% of the time it will not only not give it enough power to charge when its on, but it drains it faster than if I just leave it unplugged!
I've tried just charging the phone when its turned off as well. I'll go to bed with the phone turned off at 10% battery, leave it plugged in and charging all night, but end up with 8% battery when I turn it on in the am. Weird thing is I *always* make sure the solid red light shows its charging before leaving it. It's like 99% of the time plugging it in actually sucks power from the phone...But when I dont have it plugged in the battery doesn't drain fast at all, its functioning completely normal.
Is there anything you can suggest I do aside from actual hardware replacements?
