Root How do I flash oxygen hboot?
abnoir
Hi guys, apologies if this is a silly question but I am confused.
First of all I've rooted and s-off'ed my desire using revolutionary. I then partitioned my sd card with Rom manager and then flashed with oxygen 2.3.2.
Everything seems to be working fine at the minute, but the final step is flashing with the oxygen HBOOT to get more space for apps. I've read countless post that direct me to alphaRev 1.8, but most are from 2011/12, and the alphaRev website says that it is depraceted. My question is how do I flash the correct oxygen hboot for my rom? Is the alphaRev method still OK to use?
Thanks, and help much appreciated :)
You still get the hboot from alpharev.nl, and the instructions for flashing it are correct.
It's the alpharev S-Off tool that has been superceded by Revolutionary, but as you are S-Off you don't need that anyway (plus it still works, just not on the latest software releases).
