How do I format SD in FAT32?
Oreosnax
Hi folks!
I understand from my previous thread that I need to get a new SD card, and format it in FAT32
But how do I do that?
I have only android devices. I haven't seen anywhere that let's me choose
I did a search of the forum here, and the only thread I found coming close to this topic was this long and cranky one, which did not resolve the issue:
Thanks very much for any help!
I have a Galaxy S20 phone running android 13, and the replacements for my dead tablet I've been looking at seem to all run android 11
its better if you insert the new sd card into your tablet. then go into settings>storage>format sd card. it will automatically format the card for you. now if does not see the new card formatted or not, then the issue is with the tablet. and my suggestion is to return it and get a different one....not the same one, a different one....preferably a better higher end one.
To be clear, I'm not asking how to format a card
I'm also not asking how to choose whether it's formatted as Internal storage or a portable storage
Instead, I'm asking how to have it specifically format it as fat32, using an android device
Woohoo! Thank you AugieTN!!!
That app was mentioned in the thread I quoted, but the person on that thread said it only worked on a rooted device. I didn't want to do that
But I assume from your post that it's not necessary?
DevCheck says "Filesystem sdfat". What is that?
Wikipedia has no entry
I found an arduino site:
"The SdFat library supports FAT16, FAT32, and exFAT file systems on Standard SD, SDHC, and SDXC cards."
This does not help me to know whether I have FAT32 or exFAT
Any ideas for next steps?
I sure appreciate your folks' help on this!
......Any ideas for next steps?.......
Yes, put it in your tablet and be done with it.
I appreciate your efforts, but the whole point here was that I bought a tablet, and my SD card didn't work in the tablet
I thought the problem was the tablet, so I returned it and bought a different one,different brand
and the same thing happened!
My old tablet anf my phone can both read the sd card fine, but both new tablets an not
before I buy a third tablet, I'm trying to figure out what's wrong
people here suggested that the problem was maybe that it wasn't formatted FAT32
So now I'm trying to figure out how to do that.
If it says "sdfat" that means it's either exFAT, FAT32, or FAT16.
It might be possible to use ADB to get more info or format to FAT32. Or use a computer - Windows defaults to FAT32 if it's 32GB or smaller and exFAT for 64GB or larger so you might need 3rd party partitioning software.
