Flash Player 4.x and it works if you use a browser that handles Flash, like Dolphin or Next and run them in Desktop mode. (In phone mode you get the mobile version of the site, like m.cnn.com, which doesn't use Flash.)
Thanks Rukbat,
Is it advisable to change browsers? I'm not very experienced in this stuff, please forgive all my questions. The stock browser is running really well. I'd hate to screw up the phone. If I tried Dolphin and it bogs down the phone can I easily return to the stock browser if I don't like Dolphin?
Thanks,
Matt
Hi
If you upgrade to android more recent than 4.1 then I believe the stock browser will no longer support flash even if installed so you then need Dolphin which provides the necessary software support. I've had no issues with downloaded Flash player working using 4.1.2
Roger
I use the stock browser on my Note II and it plays Flash fine (once you've downloaded Flash, obviously). I don't get why everyone always suggests using Dolphin or any other browsers any time Flash is discussed.
To answer your question tho, changing browsers is fine. You may even find one you prefer to the stock browser.
Hi
Roger
I'm running 4.3......stock browser plays Flash fine![]()
It appears as if some underlying changes in Android 4.4 Kit Kat interfere with the APK installation and subsequent working of Flash Player on that version of Android
OK, I downloaded "flash player "ics.apk". When I try to install it, I get a message that says ""Install BLocked, For Security, your device is set to block installation of applications not from Google Play" I unchecked "Unknown Sources" and I got a message that says "application installed". How do I know if it's working? What website can i go to to see if it is?I'm running 4.3......stock browser plays Flash fine![]()
Thanks,
Matt
All you need to do is click on the flash player app. Your browser should open and should show you the settings for flash player. If it does not show the settings when browser opens. Then its not working. Pretty simple.Hey! I think it's working! On Flip Box, there is an advert for "Zuck" with a looped picture. So I guess flash is now working on my phone. I haven't seen anything on the CNN app but I'm going to go to their page and see what happens.
It's set for "Multi Storage", is that the best choice?All you need to do is click on the flash player app. Your browser should open and should show you the settings for flash player. If it does not show the settings when browser opens. Then its not working. Pretty simple.
Yes, that's fine.It's set for "Multi Storage", is that the best choice?
Matt
Yes, that's fine.
