Help How Do I ignore An Incoming Call?
Xenon
I don't know how to ignore an incoming call! I press menu, press and hold menu and I never get the option to ignore. What gives?
Press hangup to kill the call - of course the other guy will know you hung up because it will go to voicemail or hangup too early :)
Or press volume down to mute the ringer and 'ignore' so it rings out
Thanks. I thought of both of these "solutions" myself :) but
there has to be a "legal" way to do it, I'm just missing the
obvious. Perhaps the proximity sensor works there too and I
should just turn the phone face down on the table?
I mean you tap volume down and it mutes the ringer for that call. You don't need to keep it held down to alter the ring volume, and the ring volume remains as it was for all future calls.
Ah... that would probably be it then. I didn't get it the first time.
I'll try that when they call me from work next time and let you know.
It was the same on my WM phone (volume down). So I just checked in case i was going crazy and just assuming - it works the same on android :)
Its handy because you can do it through the case
