How do I keep streaming uninterrupted?
cmonster
Member
Hi all,
I use StreamFurious pro to stream online radio to my Eris and love it except for two things. It takes awhile to buffer and start playing is one. But I consider this to be the nature of the beast. Since I am listening to Internet radio over a Cell network, I gotta take what I can get.
but, it is annoying that when I am listening and I get a call or a txt, the sound dies out and so I can hear the notification. Then, when I've ignored the call, (which I usually do), the stream has to re-buffer. Is there anyway to avoid this happening? It's esp. annoying with txts which don't require sound at all.
Thanks for any advice!
Charlie
It's probably a matter of the data connection being interrupted for the call/text, as opposed to a sound setting. I'm not positive but that'd be my guess. Try using it on wifi, it should continue uninterrupted if this is the case.
