F frugalman Newbie Sep 8, 2012 #1 when I am at a mall for example, I cannot hear my notification sound at all. I installed volume+, but it crashes soon after I start it up. I am using ICS 4.0.4 and a galaxy note. I am not using custom ROM.
alpha0990 Android Enthusiast Sep 8, 2012 #2 If you root your phone, you will be able to put a custom tone in the folder where the notification files are.
GiggityGiggity Android Enthusiast Sep 9, 2012 #3 alpha0990 said: If you root your phone, you will be able to put a custom tone in the folder where the notification files are. Click to expand... You don't need to root your phone to do that, just a file browser.
N nikashri Lurker Sep 10, 2012 #4 I know this is totally wrong topic but i search for two days but not found the answer to my problem. I've got no sound at all when i plugged the charger. And also no sound when the battery is low. I've checked /system/media/audio/ui and Charger_Connection.ogg and TW_Low_Battery.ogg are still there. I want the sound back. Help me somebody.
