How do I move widgets to another screen
  • Start date Start date
A
Android Question
Guest
Hi all, my weather/news widget has moved from screen no.4 to screen 6 and I don't know how it happened or how to move it back. Help please.
Hi
2 ways
Either delete it from its current screen and re create it where you want it (normally long press the screen - select widget and then choose the one you want)
Or
Long press the widget and drag it and hold it at the side of its current screen to move it across to the adjacent screen, then repeat. This needs there to be space for it on screen 5 and is a bit hit and miss on my phone.
Roger
Hi, welcome to Android Forums.
To move an app or widget you long-press and drag it to the screen you want it on. It's not too difficult to do this inadvertantly when scrolling through your screens - I do it quite often. :rolleyes:
Just long-press your weather widget on screen 6 and drag it onto screen 4 and release it.
