How do I post a question?
Your forums are so helpful and I've spent all night trying to find an answer to a problem I'm having with the Handcent Emoji's on the Motorola Atrix, but I can't figure out how to post a question or how to get to the Handcent app thread. I'm sure it's right in front of my face, but I can't find it! Thanks!
Hi there, welcome to the forum. There's many different threads about handcent, so Im not sure which one to direct you to. However, if you'd like to post a question, you're more than welcome to. Below are a couple sections where you can post your problem/question....
Motorola Atrix 4G - Android Forums
Android Applications - Android Forums
All you do is go to either place (Android applications might be best so that other users may see it if they're having the same problem), then click on ...
and post a new thread about the problem you're having. Make sure to include all the relevant details about your phone, and a complete description of the problem you're having, and hopefully someone can help you solve it :)
Welcome to the Android Forums!
Well first off support threads for the Motorola Atrix can be found here...
Atrix 4G - Support and Troubleshooting - Android Forums
For Android Applications (in general), you can post here...
To post a question look for the
in the upper left hand part of the page. Click on "New Thread", enter a title, enter the text of your message in the main body, and then click "Submit new thread" to post the question.
