Is there a way to properly close out googlemaps when i am done using it? I notice that there isnt a exit program selection button when i press menu so i just press home. Either that or i just dont know where to look. I notice that when i goto my batter life menu, it shows that Maps is running and draining my battery tremendously after just a minute of use.
Coming from a blackberry which i use googlemaps alot, if i just press home, the program will still run in which it drains tremendously as well. I had to manually select exit program..
