As a former Droid owner, I can easily explain TWO ways to uninstall an app:
1. Go to Settings --> Applications and scroll down to the one you don't want. Click uninstall.
2. Open the Play app, which will take you to the Play Store. Under APPS, click the 3 lines in the upper left corner and select MY APPS. Scroll down and find the one you don't want, and uninstall it.
