How do i remove q slider
  • Start date Start date
A
Android Question
Guest
I would like to remove the browser option that comes up on the Q slider without being able to put it back.If this isn't possible can I install a lock?
Hi
With an app such as applock by Domobile you can apply a password lock to almost anything you want. If you use it make sure you note the password!
Roger
