Now I cannot find how to remove the pin lock and go back to just swipe to unlock. Help?
Settings>Device>Lock Screen>Screen Lock. From there it will ask you to confirm the pin. Then you pick Swipe (no security).
Tried that first thing and swipe is grayed out and is not selectable. Says "turned off by administrator, encryption policy, or credential storage".
set a pattern lock and try to unlock the phone with a "bad pattern" for 5-10 times, it will show you an error message, now select "Forgot Pattern?" and enter your gmail/password. it will then take you back to the screen unlock settings...just hit the back button and it leaves you with no screen unlock and yet the foxfi works...
