How do i reshare post using Facebook app?
Andima
Hi!
Is it possible re-share our friends post using our Android Facebook app? I search it on the Google but i can't find relent help!
Not possible as far as I know within the app. Can't do it either on Facebook mobile. Might be able to if you go to the desktop version of fb.
Depends on what the post is. If its a picture, open the picture>menu button>share. Do not open the comments section, the picture itself. If its a link, open the link then use the browser's share function.
I think he means when you click the share button on fb it then says so and so shared link via so and so.
Thanks for the info! I need to try it.:)
Yes i want know are there anyway to share every post. :D
Everything? But even Facebook on desktop doesn't have share status posts, just pictures and links, so I doubt they'd have it on the app.
No you are partly correct. FB only display share link only for links and pics, video etc (its correct).
If you need to share someone status update, click it "Status updated time display" link. That i mention following screen shot. and open it in new tab and copy that link in your status update box. ;) Yes this is a trick! :)
