Do you mean you deleted the systemUI.apk (which requires root to do)? If so the simplest is probably to restore or reflash the whole ROM. You should always take a nandroid backup before messing with system files.
If you mean something else then you'll have to post again to tell us what.
Really we'll need more information about your device and what you did in order to give a good answer.
