Help How do I set a custom sound for Text Messages?
Homeuser66
Hi, I used to have a BB and whenever I got a text message, I used to get an "ut-oh" sound which I was used to for years. I can only change to what ever stock sounds are on the phone. Any ideas would be helpful..
Thanks in advance!
Simple task. Im sure that you know how to add music to your phone. Correct? Simply add your custom ringtones to the same library. Next, go to SOUNDS, Notification Ringtones, Music, then choose the desired notification.
