I got an SD card, and figured out how to put it into my pixi but had difficulty having the tablet use it. I put it into my cool pad phone but I am not seeing how to put apps onto it. What can I do?
Not many apps can be moved to the SD card... it's generally used to store photos, videos, files and music, leaving more room in the device's internal memory for apps. You can use a file manager like Solid File Explorer to copy or move files from internal memory to the (external) SD card. Also, if you use your device to take pictures, go into the camera settings and make sure it saves pictures to the external memory. I hope this helps
If I'm not mistaken, Amazon Music streams your music from your online collection. I don't think there's anything to move. As far as audiobooks go, there may be a folder called "Audible" or whatever... you can move that to the SD card, but make sure the app knows to look on the card for the folder.
