Apps How do I wait for LocationClient to connect?
oneeyeman
Hi, ALL,
I am trying to implement the GooglePlayServices in order to get the location of the phone.
I followed the official Android tutorial and now am stuck.
Here's my code:
Code:
class MyActivity extends Activity implements  GooglePlayServicesClient.ConnectionCallbacks,  GooglePlayServicesClient.OnConnectionFailedListener
    @Override
    protected void onCreate(Bundle savedInstanceState)
        super.onCreate( savedInstanceState );
        context = this;
        if( servicesConnected() )
            client = new LocationClient( this, this, this );
            Intent intent = getIntent();
            Bundle bundle = intent.getExtras();
            device = (Device) bundle.get( "device" );
    @Override
    protected void onStart()
        super.onStart();
        if( client != null )
            client.connect();
            UserListAdapter adapter = new UserListAdapter( this, R.layout.grid_user, friends );
            setContentView( R.layout.main_screen );
            GridView view = (GridView) findViewById( R.id.view_users );
            view.setAdapter( adapter );
    @Override
    protected void onStop()
        client.disconnect();
        super.onStop();
    @Override
    public void onConnected(Bundle arg0)
        AsyncTask<Void,Void,ArrayList<Device>> task = new AsyncTask<Void,Void,ArrayList<Device>>()
            @Override
            protected void onPreExecute()
                pd = new ProgressDialog( context );
                pd.setMessage( "Retrieving nearby friends..." );
                pd.setCancelable( false );
                pd.setIndeterminate( true );
                pd.show();
            @Override
            protected ArrayList<Device> doInBackground(Void... params)
                currLocation = client.getLastLocation();
                device.setLatitude( currLocation.getLatitude() );
                device.setLongtitude( currLocation.getLongitude() );
                DBCommunicator db = new DBCommunicator( getApplicationContext() );
                try
                    friends = db.updateLocation( device );
                catch (ParseException e)
                    if( pd != null )
                        pd.dismiss();
                        pd = null;
                return friends;
            @Override
            protected void onPostExecute(ArrayList<Device> result)
                if( pd != null )
                    pd.dismiss();
        task.execute( (Void[]) null );
The problem I'm facing is that right now I'm calling "client.connect()", but this call is synchronous and when I later trying to use the object that needs to be made after successful connection and retrieval of the location it is NULL.
I tried to wrap the call to "client.connect()" in an AsyncTask<Void,Void,Void>(), but unfortunately, this is also didn't help.
So my question is: what is proper way to wait for connection and retrieving the data from cloud, so that the UI won't crash and its thread won't be stopped?
Thank you.
[EDIT]
Basically I'm looking for the same algorithm as in the Navigator.
Presumably it starts a thread where it asks for a location and then calculates the route but the map is not fully drawn until after the calculation is finished and the location/route are established.
[/EDIT]
