How do you sort apps by device?
It used to be just click my apps and it would show you all all the current apps installed on your device with an easy uninstall button beside each one. Now it shows every single demo I've ever downloaded and I can't even find the uninstall button anywhere on the site.
How do I only look at the apps currently on my device? And where is the uninstall button for them?
Sounds like you're under the "all" category.
From the main playstore page on your device, its easiest to just hit menu and then "my apps"
