How do you turn on/off 3G GPRS setting?
droiduzr2
I had a program that I got from the Market...I think it was called something Settings. It was a green color "gear" icon.
I think that was the program. It let's you control all of your settings for the most part such as wifi-gps etc...
For the LG EVE where do you go to turn on or off 3G?
I do not have data anymore.
I had a setting where I could turn on and off the 3G GPRS.
I no longer have that feature.
btw- turning off all the useless crap and using an app killer gets me a solid 2 to 3 days on 1 charge.
I think the app you are looking for is called "Quick Settings". It will adjust your light, Ringer, Volume Control, Bluetooth, Wi-Fi and GPS.
There are "Hidden Settings" which include Mobile Data and other stuff...
~Anne
thx
yes I found the app but it has changed. It did not have the multi volume control before. It no longer has the button to turn on/off the 3g feature
What do you mean by "hidden' settings?
