meatgrinder
2. Open the keyboard and press the X key while pressing and holding Power. The device will power on. Keep holding the buttons down until a yellow triangle appers.
3. Press the Search key on the keyboard (magnifying glass).
4. Use the Volume Up and Volume Down buttons on the side of the phone to select the Wipe data factory reset option. Use the Camera key to confirm it.
5. Tap wipe data/factory reset then tap OK.
6. Highlight reboot system now is highlighted then tap OK.
