Root How exactly does one FLASH a rom through cwm?
MateuszG
The title pretty much says it all. I just wanna apply a theme, but it needs to be done through CWM. So do i reboot into recovery and then open the zip file through cwm?:D:D:D:D:D:D:D
No don't open zips. Put the zip on your phone reboot into recovery and go to install zip from sd card then if it's on your external sd go to the top option choose zip from sd. If it's on internal select choose zip from internal. Then select the zip you want to flash and then hit ok. Then once it's done hit the back key and select reboot device and you're done! :)
