I'm not sure if this is everyone else's problem. I'm running Windows 7 on x64.
Install stickied drivers
Used back USB port
Set the "settings->applications->USB" to mass storage
When you connect it to a computer, pull down the notifications on your phone and click on mount. After this the computer will be able too see it.
There are other settings in that USB option too that will allow the USB to do different things like sync with Samsung's app. Good luck, hope this helps
Used back USB port
