Hi
I have just bought a Samsung Desktop Dock. OK so it's a convenient place to keep your phone while working at a computer which lets you see the phone's screen at a nice angle and charge the thing at the same time...
BUT
a) It is bad to let the phone charge too long on it?
b) Must I let the phone drain significantly before putting it back on charge?
(i.e. will constant re-topping up be bad for the battery?)
If true this would make the doc a BAD place to leave the phone for too long.
With thanks
J
P.S. Can anyone tell me why the Galaxy Note 3 has a wider set of contacts than the Note 2? (i.e. Does it matter if I attach a normal MicroUSB connector, rather than with the wider connector that comes with the phone ?)
FWIW, I have tried attaching my Note 3 to my PC (Win 7x64) but nothing seemed to popup nor be installed - is that normal?
BUT
With thanks
J
