How to access external USB when connected
hienpham
PLease someone help me to access USB stick.
As soon as I plug in the stick, It shows a message: "USB connector connected", but I don't know where it's located.
Thank you very much.
Hien
G'day Hien, welcome to Android Forums. In order for somebody to be able to answer your question you'll need to tell us what device you're using. There's a long list of tablets on the home page and a longer list of phones. Posting your question in the correct forum for your device will get you the help you need.
Best of luck with your quest, someone here is bound to be able to help.
g.e.
yah ! what device are you using so we can help you in your problem.
i know that theres a lot of here that is willing to help you.
Hien
I use ES File Explorer (free in Play Store) for this.
When the USB stick is connected ES shows it as 'USB'.
With other file managers you might look for /mnt/USB
Harry
