Welcome to Android Forums, kavyas!
An access error is usually related to permissions. You might try running the command shell as administrator. Also as alostpacket suggested, make sure you are in debugging mode and have the appropriate drivers for the phone installed. If you are not sure about the drivers, check in with the subsection for your specific phone model, or let us know what phone you are using and we can point you to it.
