hoangtruongson
How to active Galaxy tab 10.1 4G LTE verizon without sim 4g
im test two way but not ok
1:
Here it is... On the Volume rocker on the right side... hit up ONCE, down TWICE, up THREE times, and lastly down FOUR time. It will then ask if you want to bypass activation. At that point your into Setup and then the home screen.
not OK
2 :
Touch the top left corner, then top right corner, then bottom left (just above the android controls, and then bottom right (above the status tray) and last volume UP once.
You need to do this is quick sequence and you'll see the Welcome screen.
anybody help me how to active thanks all
1:
not OK
2 :
