Help how to add icons to launcher ?
kicsrules
how do i add icons to launcher ?? :confused:
rencently upgraded from 2.3.4 to 2.3.6 and now icons on the launcher are gone, only icons is menu and call .... i want to put the whats app icon right there
thnx in advanced
Press app draw button. Then press menu and select edit. From there drag the icons you want onto the dock bar. Make sure the app you use is not saved to SD card otherwise it wont be there on boot.
