Hi all,
Please I have a code which is querying an SQLite database. Basically I want to alter the color of the textview which I have in an xml file with reference to the closedate
the xml code is
and the java code is
Any assistance will be greatly appreciated.
Thanks
the xml code is
Code:
<?xml version="1.0" encoding="utf-8"?>
<RelativeLayout xmlns:android="http://schemas.android.com/apk/res/android"
android:orientation="horizontal"
android:layout_width="fill_parent"
android:layout_height="fill_parent"
android:padding="8px">
<TextView
android:id="@+id/header"
android:layout_height="wrap_content"
android:gravity="center"
android:textSize="20dip"
android:textStyle="bold"
android:textColor="#FFFFFF"
<ListView
android:id="@android:id/list"
android:layout_below="@id/header"
android:layout_above="@+id/bottom_control_bar1"
android:layout_marginBottom="45dip"
android:drawSelectorOnTop="false"/>
<TextView
android:id="@+id/firstName1"
android:layout_width="wrap_content"
android:layout_height="wrap_content"/>
<TextView
android:id="@+id/total1"
android:layout_below="@id/firstName"
android:textColor="@color/opp_child"/>
<TextView
android:id="@+id/title1"
android:layout_toRightOf="@id/total"
android:layout_marginLeft="8px"
android:textColor="@color/closedDate"
<TextView
android:id="@+id/accountname1"
android:layout_below="@id/total"
</RelativeLayout>
Code:
package mCRM.android.hp;
import android.app.ListActivity;
import android.content.Intent;
import android.database.Cursor;
import android.database.sqlite.SQLiteDatabase;
import android.os.Bundle;
import android.util.Log;
import android.view.View;
import android.view.View.OnClickListener;
import android.widget.ImageButton;
import android.widget.ListAdapter;
import android.widget.ListView;
import android.widget.SimpleCursorAdapter;
import android.widget.TextView;
public class OppMain extends ListActivity {
/** Called when the activity is first created. */
final String tag = "output";
static String Header = "Opportunities";
static String DBName =null;
static String CloseDate =null;
int layout;
protected Cursor cursor, cursor1;
protected ListAdapter adapter, adapter1;
SQLiteDatabase db;
static String TextView = null;
@Override
public void onCreate(Bundle savedInstanceState) {
setContentView(R.layout.opp_main);
TextView hdr = (TextView)findViewById(R.id.header);
hdr.setText(Header);
//home button
ImageButton home = (ImageButton) findViewById(R.id.home);
home.setOnClickListener(new OnClickListener() {
@Override
public void onClick(View v) {
Intent myIntent = new Intent(OppMain.this, Main.class);
OppMain.this.startActivity(myIntent);
//end home button
//search button
ImageButton search = (ImageButton) findViewById(R.id.search);
search.setOnClickListener(new OnClickListener() {
@Override
Intent myIntent = new Intent(OppMain.this,Global_search.class);
//end search button
//back button
ImageButton back = (ImageButton) findViewById(R.id.back);
back.setOnClickListener(new OnClickListener() {
@Override
finish();
//end back button
//database
TextView cl = (TextView)findViewById(R.layout.opp_main);
TextView cl2 = (TextView)findViewById(R.layout.opp_main1);
db = (new openDataBaseAdapter(this)).getWritableDatabase();
cursor = db.query("opportunities", new String []{"_id", "OpportunityName","SalesStageName", "CloseDate", "AccountName"}, null, null, null, null, "OpportunityName");
cursor.moveToFirst();
//CloseDate = cursor.getString(cursor.getColumnIndex("CloseDate"));
Log.d(tag, "close date:" +CloseDate);
adapter = new SimpleCursorAdapter(
this,
R.layout.opp_main,
cursor,
new String[] {"OpportunityName", "SalesStageName", "CloseDate","AccountName"},
new int[] {R.id.firstName,R.id.total, R.id.title, R.id.accountname});
int i = cursor.getCount();
Log.d(tag, "Column count " +i);
setListAdapter(adapter);
protected void onListItemClick(ListView lstvw, View view, int position, long id) {
// get the id and act name of position clicked and send to next intent as Emp_id and header
Intent intent = new Intent(this, Opportunities.class);
Cursor cursor = (Cursor) adapter.getItem(position);
intent.putExtra("Emp_Id", cursor.getString(cursor.getColumnIndex("_id")));
intent.putExtra("Header", cursor.getString(cursor.getColumnIndex("OpportunityName")));
startActivity(intent);
db.close();
public static void dataBnm(String dBNm) {
// Receive the database name from main class
DBName = dBNm;
openDataBaseAdapter.dbname(DBName);
Thanks
