auctioneeral
how do you go about assigning different ringtones to contacts. I have went into my sms menu and set ringtone for the different contacts and it still does same ringtones on both email and sms.
Check your clear notification style in LF Settings. Also, I check Pull Down Notification Bar as a catch all for when I have a couple of alerts all at once.
Android Settings > Accessibility > Services
is LightFlow on?
im I missing something on the kit kat. because wife as galaxy s4 running 4.2.2 and I just assign different ringtones to different contacts without a problem.
so is it the kit kat 4.4.2 the problem.
also could I install 4.2.2 on the nexus 5.
so I can assign different ringtones to different contacts.
Works for me.
I go into the People app, select a person, then from the menu select Set Ringtone.
